timing advancement
Old May 10, 2008 | 04:07 PM
98gstspy's Avatar
Default timing advancement
ok so i gave up on fixing my eclipse a few months ago but now its time to fix it. but my problem is that i cant fix the timing. the only way it seems to get fixed is if i advance the crank a notch or 2 i forget. the only think is that it idles high, but i know i can ajust the biss screw.
is it ok if i have to advance this or is the problem somewhere else?
130,000mi on it so yea
Old May 10, 2008 | 09:26 PM
Default RE: timing advancement
you shoudnt even be able to advance the timing any more than 1 notch (which is normally equal to about 14 degrees) without having problems with the valves hitting. So if your able to adjust the timing that much then something isnt lined up correctly. I suggest you first make sure that everything is aligned right
Old May 12, 2008 | 06:59 PM
98gstspy's Avatar
so if i had to only go one notch it should b ok then
Old May 12, 2008 | 08:16 PM
well it definetly shouldnt run correctly that way. So if it is then there is something else wrong and all your doing is masking the problem. I would try and locate the source of the problem rather than try to mask it. Something else must not be installed correctly
Old May 12, 2008 | 09:22 PM
TheAdvocate's Avatar
Do you have a 1st gen or 2nd gen Cam angle sensor?
Old May 13, 2008 | 09:22 AM
98gstspy's Avatar
2nd this all started when i replaced the head gasket so idk what is wrong. it idles funny know up down up down and sometimes it turns itself off os idk
Old May 13, 2008 | 10:33 AM
estraw's Avatar
sounds like your idle air controller (IAC) is on its way out
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
