Where is the starter?
Please give me an idea of where the starter is on a 1996 Eclipse GSX 2.0.What part of the engine is it close to? I have the Chilton's repair manual, but it doesn't help much.
Chilton's repair manual says... "for 1995-98 2.0L turbo engines, remove the air hose."
Is the air hose referred to by Chilton thesame as the"intake hose". If not, is this found under the engine?
Thanks for your help. I was able to find it. It was exactly on the left side of the intake manifold. However, I found it easier to remove it after removing the hose from the intake manifold, the battery, and the battery plate. Once those things were removed, then I had enough access to it, although several hoses/wires were still in the way. Thanks again.
