Where is the starter?
Old Jun 24, 2007 | 10:18 PM
eclipsegsx96's Avatar
Default Where is the starter?
Please give me an idea of where the starter is on a 1996 Eclipse GSX 2.0.What part of the engine is it close to? I have the Chilton's repair manual, but it doesn't help much.
Chilton's repair manual says... "for 1995-98 2.0L turbo engines, remove the air hose."
Is the air hose referred to by Chilton thesame as the"intake hose". If not, is this found under the engine?
Old Jun 25, 2007 | 05:01 AM
spinz4's Avatar
Default RE: Where is the starter?
It is under the left side of the intake manifold.
Old Jun 25, 2007 | 05:38 AM
TheAdvocate's Avatar
Its easier to go up from underneath the car.. Its on the backside of the motor..
Old Jun 27, 2007 | 07:51 PM
Thanks for your help. I was able to find it. It was exactly on the left side of the intake manifold. However, I found it easier to remove it after removing the hose from the intake manifold, the battery, and the battery plate. Once those things were removed, then I had enough access to it, although several hoses/wires were still in the way. Thanks again.
stealth1
Jul 28, 2005 12:32 AM
Smejk
Feb 11, 2005 07:34 PM
cptkid570
Dec 23, 2004 03:47 AM
Flipz
Dec 12, 2004 04:51 PM
cptkid570
Nov 29, 2004 10:49 AM
