Headlight turn switch info
Old May 5, 2013 | 12:33 AM
usatracy's Avatar
Default Headlight turn switch info
Hi,
Have a 2000 Eclipse I'm trying to fix, not having seen one before I dont know the answer to this with regards to how the hi lo beam switch operates
The lever is springloaded and returns towards the driver, you can push it forward, there is no clicking and it does not stay forward, it returns back to the driver
Is this the normal operation for the hi low switch on a 2000, where to change from hi to low you momentarily push forward on the lever, or is it broken and not staying forward ?
Thanks
Old May 5, 2013 | 12:49 PM
That is normal function. Nissans stay back, Mitsubishi you just click it back, then again to switch them off. If the switch has failed internally, then you must replace the stalk.
klevy09
Apr 18, 2012 12:57 AM
happyharold4
May 28, 2011 05:20 PM
2000MontyLtd
May 7, 2011 10:26 PM
Chris_FL
Mar 29, 2011 06:04 PM
Dumbo45
Jan 23, 2009 09:29 AM
