How to wire power antenna to new stereo?
Hello and thank you in advance for any help,
I have a 2003 Eclipse GT Spyder. I purchased a JVC head unit to replace the Infinity system. I am still using the infinity amp. Everything is working as it should except the power antenna. It will not work at all. Can anyone tell me what wire I need to attach the blue power antenna wire from the JVC unit to on the wiring harness of the car to make the power antenna work again?
Thank you again for any help...
Lingwall
Lingwall
Does your JVC not have a power antenna wire? Some mid-level to high end headunits have a remote wire and a power antenna wire. If you used an aftermarket wiring harness and dash kit, the wiring harness will have a blue for the remote wire and a light blue (or some alternate color) for the power antenna.
If not, then doing what Jsmilliken stated works fine also.
