How to wire power antenna to new stereo?
Old Apr 30, 2007 | 07:57 PM
lingwall's Avatar
Default How to wire power antenna to new stereo?
Hello and thank you in advance for any help,
I have a 2003 Eclipse GT Spyder. I purchased a JVC head unit to replace the Infinity system. I am still using the infinity amp. Everything is working as it should except the power antenna. It will not work at all. Can anyone tell me what wire I need to attach the blue power antenna wire from the JVC unit to on the wiring harness of the car to make the power antenna work again?
Thank you again for any help...
Lingwall
Old May 1, 2007 | 11:54 AM
Dusty Eclipse's Avatar
Default RE: How to wire power antenna to new stereo?
Im not even gonn ask why youd replace Infinity with JVC.... but, Ill tell you do a searchon here for the wiring and youll learn how.
Old May 17, 2007 | 11:07 PM
jsmilliken's Avatar
just hook the power antenna up to the same wire as your amps aslo called remote wire and it will come on every time you turn on your deck
Old May 18, 2007 | 12:39 AM
silvercoupe97's Avatar
Does your JVC not have a power antenna wire? Some mid-level to high end headunits have a remote wire and a power antenna wire. If you used an aftermarket wiring harness and dash kit, the wiring harness will have a blue for the remote wire and a light blue (or some alternate color) for the power antenna.
If not, then doing what Jsmilliken stated works fine also.
jdohe
Dec 12, 2010 07:00 AM
aluminody
Aug 5, 2010 11:47 PM
eclipse003g
Jul 8, 2009 04:00 PM
youngowner
Dec 7, 2007 09:15 PM
faded2
Jan 19, 2006 08:43 AM
