91' eclipse gas pedal
Old Feb 22, 2006 | 03:17 PM
19eclipse91's Avatar
Default 91' eclipse gas pedal
my gas pedal in my 91' eclipse is extremely stiff, and when i let off its delayed and sticks a little bit, some of my friends told me to use WD-40 or something like that, but i'm not sure where to put it.
Old Feb 22, 2006 | 05:30 PM
NESpeed's Avatar
Default RE: 91' eclipse gas pedal
First go get some carb cleaner NOTHING BUT CARB/THROTTLE CLEANER!!and clean your throttle body......if it still persists then check you gas peddle cable, but most likely its just a dirty throttle body.
Old Feb 22, 2006 | 11:16 PM
thanks, i'll try that
Old Mar 5, 2006 | 12:38 AM
i checked my throttle, and its loose, so is the cable going to the throttle, any other ideas on why my pedal is so stiff?
Old Mar 5, 2006 | 07:36 PM
maybe check the coil on the back of the trottle body, i know i had that problem. Just spray some WD-40 on the small coil and it should fix it.
Old Mar 6, 2006 | 05:38 PM
yeah, i looked at that, and i think thats what i need to do, thanks
carlover626
Nov 17, 2007 04:29 PM
p6793026
Nov 2, 2007 03:03 AM
nktaylor
Feb 27, 2006 03:55 PM
Angel_408
Mar 1, 2005 05:20 PM
