Sponsored by:
Sponsored by:
98 GS clutch pedal issue. Please help!
Old 03-27-2006, 11:21 PM
koodalgo's Avatar
Default 98 GS clutch pedal issue. Please help!
My 2G GS suddenly started having some issues with the clutch pedal. One moment it was driving fine, and the next it started vibrating as I was pressing the pedal down. The clutch is about a year and a half old. And it's not slipping at all. The car is accelerating just fine. The only problem is the vibration when I press the pedal down and a slight popping feeling when the clutch is pressed all the way in.
A couple of people have suggested loss of hydraulic fluid. Does anyone have any educated guesses??
Thanks in advance for any help.
-k00
Old 03-27-2006, 11:42 PM
slow420a's Avatar
Default RE: 98 GS clutch pedal issue. Please help!
could be that, maybe the master cylander has dirt or soemthing in it, also could be the throw out bearing. Best thing to do its to flush a good amout of dot4 though the thing and then fill it up with dot4.
Old 03-28-2006, 12:07 AM
koodalgo's Avatar
Thanks i will try that.
If that does not work, does that mean the master cylinder is bad? And how much does that part cost?
And what does the throw out bearing do? How can I tell if it is the bearing?
thanks!
chutney374
10-02-2010 11:48 AM
brianwis
09-22-2009 09:09 AM
wicked2407
10-25-2006 06:07 PM
blk beauty 3kgt
03-29-2006 02:28 PM
jfvalejandrino
06-08-2004 06:07 PM
Quick Reply: 98 GS clutch pedal issue. Please help!
