ABS/ASC/4WD lights on after fr wheel bearing change
Old Jun 12, 2019 | 02:12 PM
shelaghkesler's Avatar
Default ABS/ASC/4WD lights on after fr wheel bearing change
Hi all. I have just replaced my front right wheel bearing and now have ABS service required, ASC service required, and 4WD service required lights flashing. After unhooking battery to reset they were still on. Took to a mechanic shop to have them hook up code reader and reset. They reset but the 4WD light would not go off. Left mechanic shop and about 5 seconds driving all the other lights came back on. Do I need to replace the wheel sensor? And if I doh does it take care of the 4WD light as well? Also, when the other lights were off the 4WD service required message was replaced with 4WD system overheat, please slow down. When the other lights came back on it went back to 4WD service required. I have ordered a new sensor in hopes that all will be corrected. Any help or advice would be greatly appreciated. This is on a 2015 Mits Outlander SE 2.4l
Last edited by shelaghkesler; Jun 12, 2019 at 02:15 PM. Reason: forgot make and model in thread
Old Sep 15, 2024 | 10:04 AM
Mark Denver Bautista's Avatar
Default Hi just wondering did it fix the issue whe
did it dix the issue when you changed abs sensor? I got 2014 outlander and did the same thing all light came on.. abs traction 4wd and lock..
daniiielle2991
Feb 25, 2021 11:01 AM
Bardalec
Sep 7, 2020 09:01 PM
bigdaddy12
Mar 20, 2017 02:52 PM
kreillylaw
Nov 23, 2016 04:55 AM
olijayp
Aug 6, 2012 02:53 PM
