Alternator help!
Old Apr 17, 2004 | 07:45 PM
marievalko's Avatar
Default Alternator help!
I tried posting this once before, but don't see it, so I apologize if this is a repeat. After installing a new alternator, I found a wire I don't remember removing from the alternator. It's a small yellow wire and I have no idea where it goes. If anyone has any ideas, please let me know! Thanks!
Old Apr 17, 2004 | 11:33 PM
Seth's Avatar
Yellow wire doesn't that mean earth? <IMG src=smileys/smiley29.gif border="0"></P>
Seth <IMG src=smileys/smiley15.gif border="0"></P>
Old Apr 18, 2004 | 12:02 AM
Seth's Avatar
Oh i've found your last post to it was under Galant a mod might want to delete that post after being on the forum twice. <IMG src=smileys/smiley23.gif border="0"></P>
https://mitsubishiforum.com/forum_po...D=996&amp;PN=1</P>
Old Apr 18, 2004 | 01:42 PM
marievalko's Avatar
I deleted the other post, thanks Seth! I think yellow is ground, isn't it? It's got a small clip on the end, and seems to want to go somewhere. I've got the regulator connector and the battery cable hooked back up. The drive belt is a little loose and the clock resets to 1:00 every time I turn the car back on. Could it be the loose drive belt, or would it be this yellow wire? I feel like such an idiot for not remembering these things before I took the alternator out!</P>
</P>
</P>
Old Apr 18, 2004 | 03:11 PM
Seth's Avatar
Clock with a drive belt no match. <IMG src=smileys/smiley5.gif border="0">Might be the yellow wire connect it to the chassie "ground" and see what happens. <IMG src=smileys/smiley20.gif border="0"></P>
Old Apr 19, 2004 | 02:39 AM
Spyderman9803's Avatar
yes its a ground
Old May 3, 2004 | 03:25 PM
marievalko's Avatar
Does anyone know where the ground wire plugs into? From what I understand, the chassis, but I'm not quite clear on what that is or where the slot to plug it into is. Thanks for all the help</P>
Old May 5, 2004 | 11:45 PM
find any nearby bolt that connects to the metal frame.
Old May 6, 2004 | 04:51 PM
91eclipse's Avatar
ground man...about 95% sure
molotov
Jan 8, 2007 08:58 PM
exquizit23
Oct 17, 2006 11:48 AM
picaxkillr
Jul 28, 2006 11:47 PM
bedjemp
May 19, 2005 02:02 PM
m3kgt_99
Sep 20, 2004 02:22 PM
