Clutch problems
Old May 16, 2005 | 02:46 PM
stephmar's Avatar
Default Clutch problems
I have a 95' eclipse whenever I push in the clutch for more than less than a minute it dies. It starts up fine and drives okay it just has a poblem when I push in the clutch. If you have any ideas what the problem might be please let me know..
Old May 16, 2005 | 02:56 PM
pc's Avatar
pc
Default RE: Clutch problems
It sounds as if the clutch is not holding disengaged. Try it with the car in neutral and see if the engine stalls. I'm guessing you have it in gear with the clutch depressed and when the clutch bleeds down the engine stalls because you have it in gear and with your foot on the brake at idle. You either need a clutch master cyl'r or a slave cyl'r.
Old May 16, 2005 | 09:38 PM
stephmar's Avatar
it still stalls when the transmission is in neutral. It also produces a loud clicking noise when the clutch is pressed down.
Old May 16, 2005 | 09:46 PM
pc's Avatar
pc
Could be a bad throwout bearing? But I don't understand why the engine stalls even when in neutral, unless your clutch safety switch is bad? Do you have to start the car with the clutch depressed?
Old May 16, 2005 | 10:27 PM
DSMTalonAWD51's Avatar
are u turbo or nonturbo? does your clutch pedal ever stick to the floor after a left hand turn? does the clutch pedal pressure ever feel different than normal?
jp2000
Jan 1, 2012 05:21 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
