Clutch problems
I have a 95' eclipse whenever I push in the clutch for more than less than a minute it dies. It starts up fine and drives okay it just has a poblem when I push in the clutch. If you have any ideas what the problem might be please let me know..
It sounds as if the clutch is not holding disengaged. Try it with the car in neutral and see if the engine stalls. I'm guessing you have it in gear with the clutch depressed and when the clutch bleeds down the engine stalls because you have it in gear and with your foot on the brake at idle. You either need a clutch master cyl'r or a slave cyl'r.
wicked2407
Oct 25, 2006 06:07 PM
