Disable all wheel drive
Old Sep 4, 2006 | 11:24 AM
Manybrews's Avatar
Default RE: Disable all wheel drive
ORIGINAL: Jeffisdecentttttt
thats how we do it in oregon. i just brought my rpms to 2500 for about 30 seconds, and it was over
then your state is not an IM240 testing state. You need a load to actually test the car in real world situations, but apparently oregon isnt at that level of emissions testing.
Old Sep 4, 2006 | 11:28 AM
Manybrews's Avatar
ORIGINAL: 98eclpsrider
you don't have to spin the tires to make emissions, i thought everyone knew that, i did the emission on my mom's jeep with four wheel drive.
of course the car expells gases when its not moving; its just not anywhere near the amount that it is under load. you cant have a real test without load conditions.
Your state may not perform loaded tests such as an IM240 test.
revving the car engine in nuetral is not even a 5 percent engine load situation.
Old Sep 4, 2006 | 12:20 PM
well in mass with my AWD thats what they had to do to, just reving it. Then when it failed the guy then did it without doing anything, just the sensor in the pipe, and i still failed by double the state standard . I got rid of the car before i had it fixed but im pretty sure it was a bad cat.
Old Sep 4, 2006 | 04:30 PM
98eclpsrider's Avatar
ORIGINAL: Manybrews
what does your state have then? here in washington we don't need that, and when spinning the wheels it's the same load they keep it at the same rpm's wouldn't it bee the same load when the engine is working the same. once the wheels start going the load goes down from force of gravity.
Old Sep 4, 2006 | 05:47 PM
Manybrews's Avatar
there is certainly NOT the same load sitting still revving the engine as there is driving. You may only need 10 HP to stay at a constant cruise, but you will need 100 to get it there.
higher revs are not what creates high levels of NoX; thats caused by high combustion temps, only reached at high load situations.
An IM240 test is the nation standard in polluted areas. If you dont live in one, you probably will someday. check out a couple links for more information.
http://www.aa1car.com/library/im240.htm
http://www.wivip.com/index.html?te_im240.html
http://www.epa.state.il.us/air/vim/faq/testing.html
sk8dudety
May 31, 2014 08:55 AM
dr_max_facts
Feb 29, 2008 03:21 PM
se4448
Oct 29, 2007 03:00 PM
chillinsb
4th Generation
11
May 31, 2007 03:15 AM
trbodsm997
Dec 25, 2004 01:52 AM
