Help - Engine Hood won't open
Old Dec 29, 2005 | 05:21 PM
eduoble's Avatar
Default Help - Engine Hood won't open
I'm new to this forum, but I thought I'd give it a shot. Today, I tried changing my oil, but when I went to open the engine hood, it wouldn't release for me. I pulled the engine hood lever below the instrument panel, but nothing happened. There seems to be tension in the lever, so I do not believe the cable is broken. My guess is that the latch is stuck for some reason, but how do I get to the latch when the hood won't open? Please help if you can! 2000 Mitsu Eclispe GT
Old Dec 29, 2005 | 06:26 PM
FireDoc's Avatar
Default RE: Help - Engine Hood won't open
Have a friend put a little pressure on the hood so the latch can release easier. Hopefully, it opens and you can asess from there.
Old Dec 29, 2005 | 08:40 PM
Sanguinius's Avatar
Sometimes mechanical agitation is necessary to fix these things. Have someone holding the lever and hit it in the center of the front see if it pops. If not then try using a screwdriver (flathead) coverd in a rag insert it and try to pry the hood up perhaps the spring for the hood is too weak and needs replaced.
Old Dec 30, 2005 | 12:35 AM
Joel_CA's Avatar
This is a common occurance and may require a bit of extra force when pulling on the release. Once you get it open, be sure to lube the release area on the front latch. Good Luck!
Joel, CA
mwanafunzi
Mar 31, 2015 10:11 AM
writersmark
Mar 2, 2014 09:29 AM
crazycar2000
Oct 17, 2010 04:56 AM
Rusty1
Mar 5, 2009 07:29 AM
redeclipse
Apr 15, 2005 04:31 PM
