leaky 3.8l after timing belt replaced
Old Feb 28, 2010 | 12:59 PM
photomd's Avatar
Default leaky 3.8l after timing belt replaced
I have an 03 Montero with a 3.8L V6. At 60K miles, I had the timing belt replaced. The water pump was replaced as well as the coolant. Over the last 3000 miles, I've smelt more and more coolant. The indep. shop that did the work kept the car for 6 days without finding the cause. Now I've pulled the cover under the engine and coolant is coming from the right side of the engine and dripping off the oil filter. I've looked with a flashlight as well as a mirror and I can't trace it. Are there any coolant passages that have to be reassemled under the timing belt? It doesn't appear to be coming from the hoses. Anyone have a good idea where to look? Thanks.
Old Mar 4, 2010 | 10:13 PM
MitsMaster's Avatar
Either the water pump is leaking or there is a oring on a tub that plugs into the back of the pump. most of the time that will fill up the valley between the heads and leak down the back of the engine.
Old Mar 14, 2010 | 08:12 PM
photomd's Avatar
Thanks...I believe you nailed it.
adamsstreetauto
Feb 23, 2018 05:43 PM
Dekota
Jan 17, 2018 08:30 PM
exoticwelding
Aug 18, 2009 01:26 PM
robfrey1
1st Generation
Mar 9, 2006 01:31 AM
jmms
Feb 26, 2005 08:57 PM
