Need help front tapping
Old Jul 25, 2007 | 08:54 PM
xtremeroller's Avatar
Default Need help front tapping
Hey everyone
I have a 99 eclipse, auto trans, everything is stock except I have a cold air intake. My problem is at 40mph and under there is a tapping sound coming from the front passenger side, it only does this when I let off the gas and coast under 40mph. It stops as soon as I touch the brakes or the gas. I can't feel anything in the steering wheel when it does it and it does not effect the handling, steering, or acceleration but it is loud as hell when it does it. Any help with this issued would be greatly appreciated.
Old Jul 26, 2007 | 04:28 AM
silvercoupe97's Avatar
Default RE: Need help front tapping
I would suggest lifting up that side and try moving things around. It could be your brake calipers, CV joint, steering rods, control arms, ball joints, even the wheel bearing (unlikely, but..).
Old Jul 26, 2007 | 09:02 PM
Thanks for the info.
Old Jul 26, 2007 | 09:28 PM
Dusty Eclipse's Avatar
Is it a GSX, by any chance?
Old Jul 28, 2007 | 01:59 AM
No not a GSX. But I found the problem, I jacked the car up so I could take the wheel off and found that all the lug nuts were loose. So I took the tire off anyway just to check things out and put the wheel back on (making sure that the lug nuts were tight) and the problem went away. I should have just checked them from the start before bothering you guys, but it's done and now there are no weird noises coming from the car./
Old Jul 29, 2007 | 06:49 AM
Lil Evo's Avatar
you're lucky that didn't come flying off in the middle of the freeway.....could have been messy.
jeffgolem
Dec 6, 2006 12:34 PM
Spyder887
Aug 7, 2006 09:14 PM
paintballproam
Jul 14, 2006 06:10 PM
cnipp3173
Nov 9, 2005 04:56 PM
Dans Talon
Oct 15, 2004 11:06 AM
