no crank
Old Oct 15, 2008 | 08:37 PM
matzekm's Avatar
Default no crank
03 eclipse 3.0L no crank, think i got a starter bad cause battery tested good, didn't get the best look at the starter but gota climpse. Any suggestions? do i need to take exuast out to pull starter out or can you just take the oil filter off and slide it back? any other diag checks i should do before i go after the starter
Old Oct 16, 2008 | 08:06 AM
Default RE: no crank
have you tried to jump the car. I know you said the battery tested good but have you tried since the battery was charged. It could have been the alternator. If it still doesnt do anything after the battery was charged then its the starter
Old Oct 16, 2008 | 11:35 AM
dsm1990gsx's Avatar
If the battery is good, try tapping the starter w/ a prybar and hammer and have another person try to start the car. If it starts then you know you need a starter.
Mitsiboy
Jan 17, 2005 04:28 PM
whitestallion10
Jan 6, 2005 01:20 AM
96awd
Dec 19, 2004 07:21 AM
wildwest
Jul 9, 2004 11:54 AM
Tom97rs
Nov 12, 2003 07:58 PM
