ENGINE PROBLEMS HELP
Old Apr 25, 2007 | 12:05 AM
MT 3000's Avatar
Default ENGINE PROBLEMS HELP
I have a 1995,3000GT and itis knocking. I have had alot of work previously done to the car. Now this. There isnt any smoke coming out of the back like you would think if the engine was gone. It has a little oil pressure. What am asking is the motor gone in this car.
Old Apr 25, 2007 | 12:16 AM
Default RE: ENGINE PROBLEMS HELP
Most likely a spun bearing. My suggestion is to replace the motor.
Old Apr 25, 2007 | 12:36 AM
Dusty Eclipse's Avatar
Sounds like it... Your screen name has just come true... youll soon have an MT(empty) 3000... That is until you put a new motor in
Old Apr 25, 2007 | 02:22 PM
thestealth's Avatar
If it is knocking, yeah, your are pretty much S.O.L. Does the knocking stay consistant with RPM's?
Old Apr 25, 2007 | 02:25 PM
VR4GARY's Avatar
First, how many miles are on the engine? If you have a "little" oil pressure, does it increase when cold or at higher RPM? Does the engine shake when it is knocking?
If it is your oil pump, you will get very little pressure regardless of temp or RPM. If a plug is fouled, or a valve is damaged, the engine will knock and shake. You can use tubing like a stethoscope to find out where the knocking is coming from. Having a valve replaced is cheaper than buying an engine.
Josh45
Mar 17, 2015 12:36 PM
jp2000
Jan 1, 2012 05:21 PM
eweppler
1st Generation
48
Oct 12, 2010 08:49 PM
kermet420
Mar 13, 2009 04:02 PM
conflict97gst
Jul 28, 2006 04:29 PM
