3KGT NA Oil Pump Question on Reassembly
Old Jun 18, 2008 | 02:19 PM
stephenson's Avatar
Default 3KGT NA Oil Pump Question on Reassembly
1992 NA .... reassembled oil pump after carefully checking clearances - yes, I made hard decision to use it over vice new one.
It appears very tight - recognizing the cover plate holds the mechanism in place and is coated in oil as the rotors spin, once assembled, should I be able to turn the pump with my finders through the shaft opening where it would fit onto the crankshaft? It does not appear to be binding, just tight - and, I am assuming it is the contact with the cover plate since gears move very smoothly. I have installed it on the crank and turned it through with no issues, but am concerned about the "tightness."
Thanks!
George
Old Jun 18, 2008 | 04:42 PM
stephenson's Avatar
Default RE: 3KGT NA Oil Pump Question on Reassembly
OK, as I got into this, I found this in a couple of advisory locations ....
"Whenever the oil pump is disassembled or the cover removed, the gear cavity must be filled with petroleum jelly to seal the pump and act as a prime. Do not use grease."
Comments?
Thanks for the help!
George
Old Jun 19, 2008 | 01:54 PM
stephenson's Avatar
Help - someone must have felt the friction on an oil pump on installation ... new or used .... help!
Thanks!!!
George
Old Jun 23, 2008 | 12:27 PM
EMC 3000GT's Avatar
I don't remember what it felt like But I just just poured some oil into a bowl and then dipped the gears in and made sure they were well lubed. They don't spin very easily by hand to begin with.
Old Jun 26, 2008 | 03:21 PM
EMC 3000GT's Avatar
Can I post here.
MNalfa
17
May 9, 2019 06:07 AM
lancer0594
Feb 5, 2009 06:48 AM
SyntorX
Mar 29, 2008 12:32 AM
Dusty Eclipse
Apr 24, 2007 10:40 PM
FlipNNVH
Oct 11, 2006 12:52 AM
