Idle problems???
Old Nov 6, 2006 | 01:24 AM
reggieccrgto's Avatar
Default Idle problems???
My 92 VR4 is running but now there is a idle problem. I think it might be the EGR but I'm not sure. I could anyone give me advice?
Old Nov 6, 2006 | 02:50 AM
Joel_CA's Avatar
Default RE: Idle problems???
What kind of work was recently performed to it? You can put your hand on the EGR diaphram and push it up. If it stumbles and runs rough when you do that, then its definately NOT your EGR causing the stumble. If your battery was recently replace, you may need to clean out the throttle body/throttle plate.
Joel, CA
Old Nov 7, 2006 | 07:47 PM
Yeah I changed the battery, But I removed the the EGR pipe and I found a crack I'm goin to replace it and clean my throttle body. Hopefully that solves the problem. Thanx
jp2000
Jan 1, 2012 05:21 PM
corey17
Feb 3, 2007 02:55 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
VR4Restored
Aug 14, 2004 03:57 PM
sunditty
Jun 8, 2004 09:10 PM
