Very high idle
Old Dec 13, 2007 | 09:03 AM
lord_of_biscuits's Avatar
Default Very high idle
I have a 92 3000GT SL and the car idles at 2500 rpms and goes up and down from 1500rpm to 2000rpm when it warms up. Has anyone here found out the problem that could cause this? I adjusted the screw on the intake and brought the idle down to about 2000 rpms. After I did that, I got a little bit of white smoke from the exhaust. And is there anything that I can hook up to the computer to tell me what it is?
Old Dec 13, 2007 | 09:48 AM
underpressure2003's Avatar
Default RE: Very high idle
Mine did that to me the last time my car was ideling hight I changed my air filter because it was kind of needing to be replaced abd 2nd the car was working twice as hard to suck air up so it was ideling high changes your air filet even if you put a intake because it it sexposed as well and about the smoke might had did that with the ideling high as making the motor work a little harder, have you changed your oil recently? And on top of that if it sitting there over night and all the moisture will allow your car to do that nothing major tho.
Old Dec 13, 2007 | 10:12 AM
thestealth's Avatar
You should check out the idle air controller to see if it is working properly. http://www.stealth316.com/2-isc-iac.htm
armymen
Apr 20, 2012 11:39 AM
lord_of_biscuits
Dec 13, 2007 08:58 AM
Ziggy
May 29, 2007 01:24 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
shmadiohead
Feb 23, 2004 05:22 PM
