04 endeavor can the pcm be the cause of misfire
Old Mar 15, 2014 | 12:26 PM
jaystihl's Avatar
Question 04 endeavor can the pcm be the cause of misfire
I have a misfire cylinder #3. changed injector, coil twice, spark plug well seals,. it only has misfire problem 50% of time, runs fine the rest of time. it can misfire cold , hot, idle, accelerating , and seems to be worse with a/c on. anyone think its a pcm? cost 400.00 , so kind of hesitant to replace it. thanks for any advice
Old Mar 23, 2014 | 07:58 AM
scottbarlow13's Avatar
I havea 05 endeavor and keep having having misfire concrrns and started smelling a burnt scent and I had a coil short out , which in return blew my ignition fusesand leftme stranded in atlanta .
Old Mar 25, 2014 | 03:46 PM
jaystihl's Avatar
it is truly one of the hardest problems i have ever tried to diagnose. something is causing the coil to overheat. if you figure it out please let me know , thanks
Old May 25, 2014 | 10:24 PM
Hon450's Avatar
Jastihl did any of that help or fix it for a bit? If its burning up coils it's wiring or the ecm ( very unlikely) a bad valve can create a miss and can be intrmitant as well
jaystihl
Mar 27, 2014 01:16 AM
Rednek Hoser
Jun 23, 2012 06:36 PM
owensth
Aug 10, 2010 02:43 PM
xp8ntballkid309x
Aug 17, 2007 06:20 PM
fireeatn1
Jun 2, 2007 06:00 PM
