02 Galant V6 Oil leak
Old Mar 13, 2021 | 04:21 PM
Peter Fanelli's Avatar
Default 02 Galant V6 Oil leak
Got a problem with an oil leak in my wife's Galant. I know it was leaking oil from the cam cover gaskets and had those replaced a while back but the problem has persisted although not as bad as before.
I decided to do an oil change for myself a couple of weeks back and found the oil filter was not even hand tight.
Bingo! Thought I'd found the problem.
I replaced the loose Fram filter with another Fram filter I had on hand and cleaned up the area a little.
All was going well, the smell of burned oil was rapidly going away as residual oil on the exhaust system flexible couplings was being burned or baked dry.
Then a couple of days ago the smell came back.
I just checked the filter, it's not loose but there is oil back in that area again.
So anyone else had this problem?
Is there a filter mount with a gasket bolted to the block?
Could it be the oil pressure switch if that's in that area?
By the way I've read up and found that Fram filters don't seem to have a very good reputation so I won't be using them again.
Somewhere around here I have a manual for that car but do you think I can find it!
Any suggestions welcome.
Old Jul 27, 2021 | 07:27 PM
Still trying to find answers for this, I'm figuring it's either the gasket behind the oil filter adapter or the O rings between the oil pump and the block.
Anyone had this problem?
JerryB
Feb 22, 2018 12:49 PM
nesser
Jun 6, 2012 08:13 PM
lancer0594
Feb 5, 2009 06:48 AM
99clipsgst
Dec 19, 2008 02:22 PM
southside
Feb 7, 2008 10:32 PM
