Antibackflow oil filter required?
Old Feb 22, 2018 | 10:57 AM
JerryB's Avatar
Default Antibackflow oil filter required?
I just bought a used 2007 Oultander 3L V6.with 113000 miles on it. It was due for oil change, and I changed the oil and filter. Since then, occasionally it will rattle (sounds like oil starved lifters) when it is first started in the morning. The noise only lasts a few seconds, but it is disconcerting. I did not notice the problem before the oil change. I know of another car that requires an oil filter with a back flow device built in to prevent this issue. Does this car require this type of filter?
The autoparts counter person said that his son's Mitsubishi does the same thing. I am not especially content with that answer.
Thanks for your reply.
Old Feb 22, 2018 | 12:49 PM
ccernst's Avatar
Mine does it. it is just the oil draining out of the exhaust hydraulic lifters. once the oil pump gets going and they are pumped a few times, they fill up and all is well. My last used oil analysis shows excellent condition, so not a big worry.
SERPENTOR
Feb 12, 2018 01:25 PM
mrdawgza
Dec 6, 2016 11:33 AM
OutlanderGT
Mar 4, 2014 04:55 PM
Tony123
Jan 27, 2011 07:50 AM
lancer0594
Feb 5, 2009 06:48 AM
