i need help!!! keeps dying...
Old Jun 22, 2008 | 11:46 PM
eklypse509's Avatar
Default i need help!!! keeps dying...
i have a 1990 galant gsx, i can start it up, and even rev it up a little, but it very quickly dies. i changed the fuel filter, the fuel pressure regulator and the fuel pump. and it is still doing it... does anyone have any new ideas i can try? thanks!
Old Jun 23, 2008 | 05:46 PM
dsm1990gsx's Avatar
Default RE: i need help!!! keeps dying...
I'm guessing is doen't idle, sounds like a bad iac motor.
Old Jun 23, 2008 | 06:16 PM
Was it sitting for a long time?
Old Jun 24, 2008 | 06:06 PM
eklypse509's Avatar
it idles for about two seconds, it will rev up if i push the gas, but then it just dies as if i turned the key off or something. it did sit for about a year and a half.
Old Jun 24, 2008 | 06:12 PM
By bet is bad gas.
Old Jun 27, 2008 | 03:55 PM
4Grim's Avatar
From your symptoms you are describing..2 things come to mind:
1. A bad MAF sensor. Get a known working one and swap it out with the one in your car currently and see if that fixes your problem.
2. Capacitors in the Ecu are leaking. The way to check is to remove the Ecu and open up the case and you will see if the capacitors are leaking. If they are and depending on the damage, the Ecu can be repaired or you will need a new Ecu completely.
dorian7
May 6, 2008 02:23 PM
dorian7
Jan 15, 2008 05:01 PM
Gregory
32
Dec 22, 2007 10:58 PM
1990GSX
1st Generation
46
Nov 10, 2005 11:08 PM
get435
May 22, 2005 03:12 PM
