Octane
use the MINIMUM suggested.
the 4 cylinder uses 87. Use NOTHING higher.
the 6 cylinders usually require premium.
use ONLY whats recommended. using higher in a car that does not require it does NOTHING. In fact, it often causes cold drivability issues. plus, it wastes your money.
I think Econo boxes uses the Regular gas for the Lancer and Galant.
I am not sure about the Ralliart and Evo X they have turbos it might be a higher grade but not sure which one.
What I heard from Spike TV that mid grade is better but I never used it. Why? it is 50 cent more expensive and I stick to the owners's manual for recommendation
