Octane
Old Mar 24, 2009 | 02:55 PM
andry's Avatar
Default Octane
Hi gallant owners.
i want to ask, what octane do you use on your gallant? what is the best octane for our gallant?
Thanks in advance.
Old Mar 24, 2009 | 07:42 PM
Manybrews's Avatar
use the MINIMUM suggested.
the 4 cylinder uses 87. Use NOTHING higher.
the 6 cylinders usually require premium.
use ONLY whats recommended. using higher in a car that does not require it does NOTHING. In fact, it often causes cold drivability issues. plus, it wastes your money.
Old Mar 25, 2009 | 08:02 AM
FAX68's Avatar
I think Econo boxes uses the Regular gas for the Lancer and Galant.
I am not sure about the Ralliart and Evo X they have turbos it might be a higher grade but not sure which one.
What I heard from Spike TV that mid grade is better but I never used it. Why? it is 50 cent more expensive and I stick to the owners's manual for recommendation
Old Mar 25, 2009 | 06:01 PM
Manybrews's Avatar
once again, read your manual.
use ONLY the lowest octane rating recommended. NEVER, EVER use higher.
tufduck
Feb 14, 2008 05:27 PM
TMR Net Shark
May 16, 2007 01:09 AM
Natedogg89
Apr 1, 2007 12:07 PM
norahy2k
Nov 15, 2006 05:44 AM
evo fatty
Sep 20, 2006 03:46 PM
