01 Montero Ltd driver door light stays on
Old Apr 14, 2009 | 01:12 PM
misteradio's Avatar
Default 01 Montero Ltd driver door light stays on
My poor '01 Montero. The driver side door light won't turn off. It's run down my battery twice. Short of disconnecting it, is there another solution? The spring-loaded gizmo in the door that connects when the door closes appears to be OK...
Old Apr 15, 2009 | 12:50 AM
humhai420's Avatar
looks like you have some moisture in the contacts spary with wd40 or sum other good stuff . and it will work
Old Apr 15, 2009 | 12:51 AM
humhai420's Avatar
you have water or mositure in the contacts spray it with wd40 or eq
work out ok
shud
schurmana
Dec 1, 2009 05:41 PM
goden
May 15, 2009 10:38 AM
rnorrell1
Oct 11, 2008 12:21 PM
03outlander
Sep 16, 2008 01:15 AM
EcLiPsEGrRL29
Sep 29, 2005 02:59 AM
