1988 Mitsubishi Montero
#2 spark plug had died. I finally took it to the right mechanic (Eddie at API Service Center | Tires & Auto Repair Charlottesville, VA ) It was running on 3 cylinders but still running. I thought I had four issues (1) low power (2) need tune-up (3) A/C idle pulley going bad (4) exhaust leak at manifold. #2 fixed #1 and #4. Belt removed #3 since A/C doesn't work. The Montero has lived beyond the car's expected life span. Next time I read the repair manual and over-think everything from EGR valve to catalytic converter, I should remember the simple things first. It's a testament of reliability that the car is still on the road driven daily.
I have been bleeding m clutch for air and a few days later it gets soft again or after sitting. I found that it was the Clutch is leaking from under the foot pedal. what do i need to replace? Thank you.
Bought a 88 Montero sport. Everything works great but there is no power steering. The guy I bough it from said it needs a power steering gear box?? I have no mechanical skills, but have would like to give it a try if I can find the part. Any help is truly appreciated.
Thanks!!
Nice ride. Scour the net for parts. There are some salvage parts sites where you can put in request for a specific part. They'll call other scrap yards and try to find it for you. First figure out what needs to be replaced - is it a PS pump, or the PS box. Add fluid to the pump and run it, see if you are loosing fluid and where. Does the pump actually pumps the fluid? You probably can run the truck without the power steering, you just going to have large biceps after some time
hello i have this with 2.6l and carburator, does anyone know how to set carburator mix so that it does not consume so much gas. i allready change all gaskets, low and high jets as per specs, vacumm etc. now have to set gas and air screws for effcient comsumtion thnak you dvaid
Doug802
Jan 15, 2014 08:32 PM
dstar26t
Oct 12, 2006 08:14 AM
