95 Montero LS changed Timing belt, now wont run?
Old Apr 17, 2005 | 11:41 PM
dsfii's Avatar
Default 95 Montero LS changed Timing belt, now wont run?
I thought all was well after I just changed my timing belt, cause it started up and was running good, but after she warmed up it just won't idle and dies. unless i hold the gas pedal?
Any ideas? Do I have to set the timing or anything after changing the timing belt?
Also, truk ran fine before the belt change...
Old Apr 18, 2005 | 12:12 AM
wicked_outlander's Avatar
Default RE: 95 Montero LS changed Timing belt, now wont run?
sounds like....your timing got messed up.
Old Apr 18, 2005 | 12:25 AM
dsfii's Avatar
Would it cause that? I swear by all means I made positive that the cams were aligned exactly on their mark, and so was the crank.. I even rotated by hand the crank a couple times and they still fell back into the aligned positions??
Old Apr 18, 2005 | 12:35 AM
try to reset your computer, unhook your batt. ( positive first, then neg.)then hook it back up (pos. then neg) sometimes pcu' needs time to recognize parts / new parts. same thing happened to me before, i, installed new pressure reg. ( fuel ) and engine management system ( piggy fuel) when i, started the engine, it last for a minute then it stalled. so confuse, i, re-program the pcu. then i, start it again...engine stall twice, but manage to keep up on the third time.
Old Apr 18, 2005 | 12:37 AM
by the way, when you let go the pedal....does the engine still run??
Old Apr 18, 2005 | 12:43 AM
let it run for about 5-8 minutes, let it warm up.....u' might notice the engine is about to stall, then comes back again....thats normal, (computer is recognizing / re-setting ) if everything fails, then advance your timing to 2-3 clicks.
Old Apr 18, 2005 | 02:56 AM
dsfii's Avatar
Ok, weird I went back out about 30 minutes later and it started fine and ran. drove around the block and did just fine??? haha.. Not sure if I trust it just yet but,,
What you said advance timing 2 clicks? How do you do this?? Where is timing adjustment?
Old Apr 18, 2005 | 04:23 PM
you did good, its the computer system recognizing new part / parts. all mitsubishi's are like that, just remember,everytime you disconnect that battery for long period, you will experience engine stall right after you connect the battery. timing advance is kinda hard to explain, you will learn it soon. anyway, thats another mitsubishi motor experience....good to go.
Old May 10, 2005 | 03:08 PM
Winshawn's Avatar
Advance timing a few clicks? There is no distributor. There is no way to advance the timing.
marx88
Jun 30, 2011 03:54 PM
raycam2kx
Feb 21, 2008 11:08 PM
Wi_Fibre
Jan 16, 2008 12:17 PM
raycam2kx
14
Oct 6, 2007 08:31 PM
raycam2kx
Aug 16, 2007 08:33 PM
