99 Montero Alternator Fuse?
Old Nov 23, 2010 | 08:34 AM
ricseay's Avatar
Default 99 Montero Alternator Fuse?
99 Montero Sport, where is the alternator fuse link located? New battery and alternator but car dies after running a few minutes. Recharge battery, starts and runs until battery is drained. Alternator tested okay, told there is a fuse link that may be blown. There is a fuse panel on fender under hood, not sure what I am looking for.
Any help would be appreciatted. Thanks
Old Nov 23, 2010 | 09:38 AM
CharlesT's Avatar
It will be under the hood in the fuse box you can check it there bad by looking through the top be shure to pull them out and check for corrosion on the pins.
here's what they look like.
http://www.autozone.com/autozone/par....diyprod4-b2c7
Old Nov 23, 2010 | 10:43 PM
ricseay's Avatar
Fuse looks good, could not get it to pull out. Do I need to loosen the screw on the side?
Old Dec 4, 2010 | 12:16 AM
jgbrules's Avatar
yes u do. if that fuse isnt blown, get somebody else thats competent to check your alternator output. usually oil leaks onto the alternator and slowly kills it. VERY common on montero.
holyghostthug
Oct 15, 2022 05:56 PM
drp37
Mar 19, 2014 05:14 PM
pulpfiction2121
Apr 27, 2008 03:41 PM
eotlou
Dec 15, 2005 05:45 PM
bedjemp
May 19, 2005 02:02 PM
