Ac not working
Old Jun 11, 2015 | 07:25 PM
2001 montero's Avatar
Default Ac not working
I have no power to the compressor. The freon checks OK 100 psi . any ideas? O yea the 25amp fuse is good also.
Old Jun 12, 2015 | 01:33 AM
I don't think that is the right fuse. You need to check fuse #19 (10A) in the engine compartment. That one is responsible for the AC system.
Old Jun 12, 2015 | 06:49 AM
I checked #9 OK. What about relay #f. swopped # c, d. they are OK. But f is different.I checked the three wires going to the comp. And no power to any of them.
Old Jun 12, 2015 | 05:24 PM
Originally Posted by 2001 montero
I checked #9 OK.
Maybe yours is different, but on mine it is #19 that runs AC, not #9.
If that checks out, check if you are getting power to the ac relay (if you know which one it is). You can also bypass the relay and see if you get juice on at the compressor.
Old Jun 13, 2015 | 02:35 PM
Got it working! The problem was the #f relay. I just took a chance and replaced it. Thanks for your help.
Pajoz
May 18, 2017 12:31 PM
kostovski.dragan
Jul 30, 2014 04:55 AM
scitron
Nov 23, 2007 06:03 PM
badnasty03
Nov 22, 2005 08:13 PM
bxdiamante
Jun 22, 2005 10:33 AM
