another timing belt question
Old Aug 9, 2010 | 04:39 AM
jig's Avatar
jig
Default another timing belt question
first time poster but been browsing the forum for a while, my question is i just change my timing belt ,my camshaft sensing blade and camshaft sensor on my 2002 montero sport with 3.5 engine, i believe i timed everything right interms of the crankshaft sprocket two camshaft sprocket to the topdead center, now the problem is the crankshaft pulley is not timed(it's way past the T mark) to the timing mark bracket that's mounted on the accesory mount assembly(the big metal cover). the car starts right away but when i test drive it it seems there's no power, do i need to timed my car using a timing light, any answer is really appreciated, thanks
Old Sep 7, 2010 | 12:09 AM
spetznazer's Avatar
Default Follow proper proceedure
Hey just download service manual from http://www.mitsubishilinks.com/
and just follow instructions. Do it EXACTLY as it says in manual.
Good luck.
judien
Mar 9, 2018 03:41 PM
Clayj73
Dec 19, 2011 07:40 PM
8000RPMS
Aug 30, 2007 05:49 AM
ultramindbrk
Jan 1, 2007 07:57 PM
speedform
Feb 25, 2005 09:00 PM
