Camshaft code 304 malfunction
Old Oct 17, 2008 | 04:18 PM
bltmonty's Avatar
Default Camshaft code 304 malfunction
Hello,
I need some help. I have a 1997 Montero. The engine won't start and the ecm shows a 304 camshaft position sensor malfunction, bank one. I replaced the camshaft sensor and then found that the power supply from the ecm to camshaft sensor was bad, so I replaced it. The harnesses all check out: power from ecm, ground, and connection to MFI are all good.
does anyone know what the Bank One means on my trouble code?
thanks for your help.
Barry
Old Oct 17, 2008 | 04:32 PM
mitsupartsman.com's Avatar
Default RE: Camshaft code 304 malfunction
bank 1 represents the cylinders on the passanger side of your car.
Old Oct 18, 2008 | 06:36 PM
dsm1990gsx's Avatar
Code p0304 is not for cam malf its for cylinder 4 missfire.
Old Nov 1, 2008 | 11:44 AM
bltmonty's Avatar
Thanks for the help. I did transpose the numberit is 340, not 304. I've replaced the camshaft sensor and checked the harness and still I get the error code. Could something else be tripping up the camshaft sensor?
Old Nov 1, 2008 | 06:59 PM
dsm1990gsx's Avatar
Could be a bad pcm if the harness and sensor are ok.
pung06513
Feb 15, 2016 07:12 AM
kxiong
Mar 7, 2011 10:08 AM
AnnaAmbrose
Dec 4, 2007 05:41 PM
MissFox98Spyder
May 26, 2006 03:58 PM
boosty
Sep 17, 2004 06:17 PM
