Fast Idle
Old Jun 5, 2008 | 10:51 AM
tdf's Avatar
tdf
Default Fast Idle
From what I have read in the Chilton, there is no idle adjustment on the 89 3.0 V6 short of getting all the parts working properly in the fuel injection and emissons equipment.
Further, it seems like the Idle Control Valve (motor)is the likely culprit.
Has anyone else had this issue with their 3.0 V6? Mine idles too fast (especially when cold) and the transition from neutral to drive gearin the auto transmission is resultantly harsh.
Old Jun 5, 2008 | 01:01 PM
Default RE: Fast Idle
Usually when the Idle Control Motor goes out, it causes the idle to fluctuate.
My advice is to reset the ECU by removing the negative battery terminal for a min, and connecting it back up. It will take a while for the car to re learn how to idle etc, but it should be okay.
Old Jun 6, 2008 | 08:08 AM
tdf's Avatar
tdf
Sebba......Thanks for the help!
Old Jun 9, 2008 | 08:29 AM
tdf's Avatar
tdf
I figured figured out the reason for the fast idle.
I had also been noticing that the truck was running cold on the temperature gauge. Initially I thought the gauge was bad. Putting the 2 together, it came to me. The thermostst was frozen in the open position!
The engine was taking, as a result, a very long time to warm up to a temperature that the computer software has stored as the temperature at which to slow down the idle speed.
Replaced the thermostat, and walah, idles normally now once it reaches set temperatute (195 degrees).
Old Jun 9, 2008 | 10:39 AM
Congrats! Sorry I didn't help.
Old Jun 10, 2008 | 09:23 AM
tdf's Avatar
tdf
You helped! You tought me how to clear the error codes out of the computer and got me thinking about the computer software!
Thanks!
Old Jun 10, 2008 | 12:27 PM
Almost all are like that by the way lol
curl
Apr 7, 2008 03:55 PM
ProjectDrknss
Aug 9, 2007 01:39 AM
yamahablaster8230
Aug 29, 2006 09:28 AM
sreps
Jan 21, 2005 08:55 PM
LancerLvr03
Jul 14, 2003 01:57 AM
