job gone bad
Old Feb 13, 2011 | 06:05 PM
2k1monterosport's Avatar
Unhappy job gone bad
had my younger brother help me with a job today and it went terribly bad. he broke the screws that attach the oil pan to the engine. half came out half stayed in...... i got srewed. so any ideas... do i just replace the whole engine? please help
Old Feb 13, 2011 | 06:21 PM
rbpwrd240's Avatar
Calm down there are several ways to remove the screws. You can try to get ahold of the stubs and twist them out or you can get a tap and die set and remove the stubs with that.
This should be enough info to get you started.
Old Feb 14, 2011 | 12:56 PM
albertinhouston's Avatar
what part of texas?
Here is something to think about.... when you tighten a bolt down it gets tight because the head of the bolt wil not allow it to go in any more. The chances of the bolt being seated all the way in are slim. with that said. sometimes you can get some Vise grips and clamp down on them then twist out. if not. drill and look for an easy out. not hard at all.
Old Feb 14, 2011 | 01:53 PM
al in houston,
brownsville, tx to be exact. yeah i gotta look closer. i was just distraught at the moment, but i gotta take a closer look. i also found metal bits in the pan along with a bolt and nut. so gotta fix something else
damuddog
Sep 11, 2010 07:27 PM
nawgee
Oct 20, 2008 06:24 AM
agallardo
Oct 1, 2006 02:07 AM
choyneth
Dec 14, 2005 01:39 AM
Eclipse4ever01
May 3, 2005 02:12 AM
