o2 sensors
Old Sep 21, 2020 | 08:48 AM
Paul69's Avatar
Default o2 sensors
can someone tell me if o2 sensors and lambda sensors are the same as im getting very confused
especially now that im trying to purchase the sensor for bank 2 sensor 2 for my truck , there are so many different types
Old Sep 21, 2020 | 05:37 PM
O2 sensor and lambda sensor It is the same thing, just a different naming convention. You should not have any trouble finding the sensirs for Montero. It is a very standard heated O2 sensor. Just look for your year/model and sensor position (B2S2). Look for a sensor that has a plug on the end. You just unplug your sensor from harness, plug in the new one and done. Avoid the sensors that have bare wires instead of the plug. Even though they might be slightly cheaper, YOU have to wire them properly. IMHO it's not worth the headache.
Old Sep 21, 2020 | 08:07 PM
Naeos_Valkarian's Avatar
Not to mention that most people are not good at properly repairing electrical connections and those wires are subjected to a wide range of extreme temperature fluctuations and water intrusion. If you have the correct skillset and equipment by all means save some money but otherwise it's just better to buy them pre-wired.
Old Sep 22, 2020 | 04:35 AM
Paul69's Avatar
ok that's great thank you so much guys ill check out the internet
take care
regards paul
pc
Oct 8, 2015 03:31 PM
cristalle
Sep 13, 2006 04:01 PM
gstTurbo2011
May 8, 2006 10:10 AM
dbarker
Sep 19, 2005 11:00 AM
perna00
Aug 29, 2004 09:38 PM
