Rear spring broken - 03 Montero
Old Apr 4, 2019 | 09:22 AM
bluvert89's Avatar
Default Rear spring broken - 03 Montero
I just discovered my rear left spring is broken on my 03 3.8 XLS. Does anyone know if the 01-02 springs work? Theres an 01 at the local pick n pull and I'd rather not drop $250 on a new one.
Old Apr 6, 2019 | 11:12 AM
carlsson01's Avatar
You can check part numbers for the ‘01 and ‘03 from internet part sellers. If they have same parts number they are same springs. That’s what i always do so I won’t get the wrong parts.
Old Apr 6, 2019 | 02:00 PM
bluvert89's Avatar
They have different part numbers, but I didn't know if that was from the change in 03
Old Apr 6, 2019 | 02:18 PM
carlsson01's Avatar
Just checkd it myself and they have different part numbers...’03 coil springs are more expensive too. They may look the same but spring/load ratings might be different.
Where are you located? Try searching at lkqpickyourpart.com and maybe they have one at a nearby location.
Old Apr 6, 2019 | 03:13 PM
bluvert89's Avatar
I'm in Missouri. Closest one is Tulsa and it doesnt look like they have any.
Any other suggestions?
Old Apr 6, 2019 | 05:38 PM
carlsson01's Avatar
Oh I see...will you be the one doing the spring swap? If you can’t wait for a used part, I guess the safest option is to get new spring from Mitsubishi part sellers over the internet. It’s almost always cheaper than getting one at your dealership.
I wouldn’t want to try installing the ‘01 springs, the ride and handling might be affected.
But wait...any plans of upgrading your suspension?
https://www.carid.com/2003-mitsubish...-coil-springs/
But then again....you have to change all 4 springs.
Old Apr 8, 2019 | 07:04 AM
bluvert89's Avatar
No plans to upgrade, fixing to sell. Will probably just order a new one.
ronwill
Feb 14, 2018 08:48 AM
markydeva
Sep 15, 2014 04:26 PM
sawc
Mar 26, 2012 02:07 PM
spk2000
Jul 15, 2011 09:15 AM
dksnj
May 8, 2007 08:14 PM
