replacing front break pads
Old Aug 11, 2009 | 06:40 PM
yuki's Avatar
Default replacing front break pads
Hi There,
New here. Have a 2003 Montero LTD. Would appreciate helo on step by step pad replacment. What should I do with the fluid? I have 06 Jeep Rubicon w/o ABS, so, I just press the caliper and insert the pads. I assume ABS is a bit more comprehensive.
ThanX, Yuki
Old Aug 14, 2009 | 12:49 PM
lovinmrv's Avatar
Default Nope
Just compress the calipers and replace the pads. Use caution not to destroy the rubber boot for the mounting bolts.
Old Aug 16, 2009 | 03:22 PM
jwhiteh's Avatar
go get a haynes or chiltons manual, it tells you how, in detail, with diagrams.
Old Aug 27, 2009 | 10:16 AM
xyzik's Avatar
Remove half of the fluid first in the reservoir so when you compress the pistons back the fluid wont spill out, don't re-use old fluid
blitzkrieg79
Sep 16, 2014 12:48 AM
OzarkXLS
Oct 22, 2007 06:29 PM
Yamama
Dec 1, 2006 12:03 PM
mjbw372d
Nov 4, 2006 10:56 PM
