Rolled My Montero, need some answers.
I was wheeling in the field behind my house the other night and rolled my 98 Montero Sport onto its side. It stayed that way for about 8 hours, when I was able to get my buddy to put back on its wheels. It was not much of an impact when I rolled it, or when I flipped it back. I changed the brake fluid, ATF, and Steering fluid. New battery, as the the old one was toast anyway, but the damn thing still won't start. Three people have mentioned some kind of cut-off switch that gets triggered on impact, and prevents the car from starting. Is this something I can reset myself? Or do I need to take it to a shop? Or, is there something else I need to take of first?
Thanks for the help, I'm really in a bind as it's my only vehicle. Any advice would be welcome.
Thanks!
Thanks!
Reset the ECU. Remove the battery for a while... and then stick the key in the ignition to drain the system of any extra power. Leave it for like 10 mins and hook it back up. Should work.
One of the least appreciated components in your fuel injection system is the fuel pump inertia switch. This little black box is designed to function flawlessly forever (or close to it), so it's easy to forget it's there. Its purpose is to shut off the fuel pump(s) in case of an accident, thus preventing fuel from being pumped all over the vehicle if there is a leak in the system. This obviously is a worthwhile thing to do, and one less thing to worry about if you are hanging from your seatbelt with your wheels in the air!http://www.therangerstation.com/tech...tiaSwitch.html
couldn't find anything better to show you fromthe internet
masond24
Oct 20, 2005 08:34 PM
