2005 Outlander rear differential clunking noise when going into drive
The clunking noise has been happening for about a month now. Cannot find anything loose. It appears to be in the rear diff. Any clues?
Hi,
did you have any luck in solving this. I may be experiencing a similar problem. I also found this other page on this forum:
http://www.mitsubishi-forums.com/ind...30&hl=Thumping
Please let me know if you have found a solution.
Thank you, Massimo.
Thank you, Massimo.
2005, axle, clunking, colt, diff, differential, end, forum, mitsubishi, noise, outlanddeer, outlander, rear, sound, support
