2005 Outlander rear differential clunking noise when going into drive
Old Mar 11, 2012 | 12:14 PM
gaparker1's Avatar
Default 2005 Outlander rear differential clunking noise when going into drive
The clunking noise has been happening for about a month now. Cannot find anything loose. It appears to be in the rear diff. Any clues?
Old Mar 11, 2012 | 03:22 PM
milliesdad's Avatar
check the u-joints. Front and rear. also the driveshaft support bearing and mount.
Old Mar 12, 2012 | 07:16 PM
gaparker1's Avatar
I guess I'll start there, thanks.
Old Mar 12, 2012 | 10:25 PM
ccernst's Avatar
not sure about the first gen, but the 2nd gen uses half shafts (cv shafts) instead of a traditional rear axle. if your gen uses half shafts, check those as well.
Old Jun 14, 2012 | 06:57 AM
cencia76's Avatar
Hi,
did you have any luck in solving this. I may be experiencing a similar problem. I also found this other page on this forum:
http://www.mitsubishi-forums.com/ind...30&hl=Thumping
Please let me know if you have found a solution.
Thank you, Massimo.
iceno9
Aug 21, 2014 08:34 AM
skipperx
Jul 3, 2012 08:59 PM
trineybopper
Jan 11, 2011 07:31 PM
Natedogg89
Apr 9, 2007 10:33 AM
blumsoccer
May 18, 2004 12:13 AM
