2007 DRL - Daytime Running Lights Disabled!
Old Jun 19, 2008 | 12:43 PM
  #31
07outty's Avatar
Default RE: 2007 DRL - Daytime Running Lights Disabled!
.........so. does anyone know exactly which relay to use ?
the o.p. described it as a "standard relay". i am not sure what is meant by "standard" .
Old Jun 19, 2008 | 01:03 PM
  #32
2g0s0r1's Avatar
I used a 30amp 4 or 5prong switching relay... it is the most basic type. when 12v is sent over the switching terminals, it closes the circuit for the other 2 terminals. kind of like a light switch... putting 12v to it is like flicking on the switch, then taking away the 12v turns the switch off.
You can get the Relay at radioshack or other electronics hobby stores, maybe at an automotive store (but youll probably just find odd ones for specific applications). Autozone sometimes has the exact relay you want hanging by the aftermarket lights and neon stuff for like $4
A good (but expensive $30) way is to buy a set of those "big red truck horns" from pepboys, the come with the exact relay you need.
All relays will have a diagram on top listing what the pins do, so you can connect it right. usually like 86a and b, and 87a and b... it does require a few basic electronics skills.
Here is one that would work great http://cgi.ebay.com/ebaymotors/ws/eB...m=120272068059
HAVE FUN! and dont short anything out.
Old Jun 19, 2008 | 03:21 PM
  #33
07outty's Avatar
......now i got it ! thanks.
Old Jun 24, 2009 | 02:10 PM
  #34
alim's Avatar
Good information -----is there a possiblity of doing the bypass within the drl relay's internal circuit?
Because I had a 2003 corolla with a drl disable/bypass by cutting some of the connections inside the relay and reconnecting the different terminals with jumper wires to enable certain functions such as the autolight feature.
While the corolla's relay was big---about the dimension of credit card--I would assume that the circuit would be similar.
Old Apr 25, 2017 | 02:35 AM
  #35
mromerov84's Avatar
What is the part number of the DRL + Headlight relay. I have problems with it and I want to buy a new one
sk8r_matt_2003
4th Generation
Jan 3, 2009 02:47 PM
neo2040
May 24, 2007 09:44 PM
jsmilliken
Apr 9, 2007 03:12 PM
AWDrivin
Feb 6, 2007 06:03 PM
jgracz
Apr 22, 2005 12:11 PM
