2007 outlander xls - coolant leak?
Old Jul 29, 2017 | 04:17 PM
xiaomeng88's Avatar
Default 2007 outlander xls - coolant leak?
went to Mr. Lube for an oil change today, and was told my coolant is leaking and sounds like a very common issue. I'm just wondering if anyone has ever seen this type of leaking. I have uploaded a photo, is it considered a serious issue? Should I go check out soon? any inputs would be greatly appreciated.
Thanks,
Victor
Old Jul 31, 2017 | 11:37 AM
binzd's Avatar
Default filler neck
The filler neck is probably shot from the inside. I replaced mine after a radiator issue two years back. The guy at the shop said that the discoloration on the inside would lead to failure. Looks like yours has failed before the radiator, which is good, because it is easily removed with a single bolt after taking the hoses off. I paid about $35 from the dealer, plus if I remember correctly, it includes a new cap, which is time for you to replace anyhow.
Old Jul 31, 2017 | 11:52 AM
xiaomeng88's Avatar
thanks for the input. will take to the dealer and have them check it out.
Stu Green
Dec 30, 2016 06:35 PM
ron
May 2, 2012 06:08 AM
ruski
Dec 30, 2010 05:32 PM
JohnOnt
Oct 28, 2006 05:22 AM
novetek
Feb 20, 2006 04:16 PM
