2010 Outlander GT- tranny or brake issues?
I recently purchased a used Outlander GT. I seem to be having issues with either my transmission or brakes. When I am at a full stop (say a stop light) and when I lift off the brakes and go to accelerate, there seems to be a very slight surge or pause as if the brakes are still engaged or the transmission is slow. Any ideas on where I need to be looking- ie brakes or tranny? Also, on a related note concerning the transmission- I was coming down a fairly steep hill, stopped and attempted to put the car in reverse and nothing happened. The car would not move back. Any ideas? Car has just under 49k on it.
at 50k, if the fluid hasn't been changed yet, do that. What does your dipstick say the fluid level is at? Changing the fluid does considerably help smooth out the shifting.
My stealership recommended every 45k miles. There is a whole thread about the differences in some stealership's tranny fluid changes. some just do a drain & fill, some get all the fluid out. I'm in favor of getting it all out.
The brakes not releasing straight away is a hill holder function. It works if you have the transmission in gear and your foot on the brake and the car is on a certain angle. When you lift your foot from the brake pedal the brakes hold for a short time to stop the car from rolling down the hill.
If you don't want the hill hold to work put the transmission into neutral and then back into drive just before you come off the brake pedal.
23C-10 AUTOMATIC TRANSAXLE
IDLE NEUTRAL CONTROL
The originally engaged starting clutch is slid to block the driving force (creep) which is generated when the vehicle is stopped with D range, improving the fuel consumption by reducing the load.
CONTROL SYSTEM DIAGRAM
Hope that helped.
AMSOIL has a J2 compatible fluid. From the transmission threads it sounds like the 2010's use J3 so check your manual or with your dealership (use your VIN) to find out what fluid spec you need.
Russk1978
Nov 23, 2010 11:45 AM
