2016 Outlander SEL DRLs not coming on
Old Jan 27, 2016 | 01:47 PM
  #41
theSaint024's Avatar
Originally Posted by guxu
How much does that relay cost? $5? $10? So Mitsubishi disabled that safety feature to save $10. I paid $22,xxx for my Outlander SE. I do not mind if they add $10 to the price.
Mitsubishi is not really giving me a straight answer as to why they are disabled. They basically said they are disabled and they will not help in activating them. I really doubt it's a cost savings issue. Something more to this that I can't understand. Since most of the bits are in there, I don't think they were trying to cut costs. I'm guessing it's some kind of liability issue but again, I can't get a straight answer from them.
Old Jan 27, 2016 | 01:56 PM
  #42
Originally Posted by turbocolts
So the question would be is it even possible to get it working? I could help you to get it to work, but unfortunately it may mean swapping to canadian spec headlights and running a relay or something to control them. The stock DRL's have a module as well as the relay, and a bunch of wiring, systems I have delt with anayways also have a resistor built in (usually used with high beam bulb DRL's which was the norm in Canada on years previous models. The new ones with DRL's obviously don't use the high beam bulbs anymore a use the LED strips.
Do your lights even have a LED strip inside the housing? On my alldata an Mitchell, they only currently provide wiring diagrams up to 2014 for mitsu's so you would have to find a Canadian dealer to find u a 2016 wiring diagram showing you how the DRL system works/wired exactly. If the US housings do have the LED strips then do they have wires and pins on the headlight housing wiring connectors. If the answer is yes, should be fairly easy to wire them to come on anytime IGN is on or something with a relay, but if the wiring, relay, DRL module is missing and the body control module (or whatever sends out the signal to turn them on/off,) is programmed differently, then it's going to be very hard to get them to work without wiring them yourslef
I would love if you or a Canadian dealer could help me solve this. The led strips are there and they work as parking lights currently. As a previous poster mentioned, we could always manually turn on the DRL by just turning on the parking lights. So it seems the important parts are there. The relay by itself didn't work. I tried that and even though they do have contacts in the relay box, there seems to be a missing piece(s) somewhere else. Fuse is there too. Is it possible for you to ask your dealer for the full wiring diagram for the DRL? I understand if not since its a lot to ask and they might not even have it easily available. It is probably one little harness or something. I will check the headlight connections next when I'm back home next week. This is silly that Mitsubishi can't provide simple guidance on this. Great mystery as to why they are being so not-forthcoming about this. Thanks for your attempt to solve this for the unfortunate US folks.
Old Feb 4, 2016 | 04:41 PM
  #43
Default Help from Canadian 2016 owners?
I read in the ETACS thread that the DRL relay might be different from the regular relay. Can a Canadian 2016 owner take a pic or check your fusebox under the hood to see? I've attached a pic of what my US 2016 fusebox looks like. I circled where the missing relay is. I tried a regular relay by just moving one over their, but it did not work. I suppose it doesn't need to be a 2016, since the ones after 2012 did not have DRL, but just to be safe. Any help from up north would be GREATLY appreciated. Thanks.
Old Feb 23, 2016 | 12:08 PM
  #44
bump. Any friends up north able to take a pic of the fusebox?
Old Feb 23, 2016 | 08:14 PM
  #45
turbocolts's Avatar
My outlander is currently in the body shop. Should be getting it back late this week.
Old Feb 23, 2016 | 09:39 PM
  #46
Copper penny's Avatar
Smile
What Happened to your Outlander? Glad to hear your getting it back.
Old Mar 6, 2016 | 06:04 PM
  #47
Thanks to turbocolts for hooking me up with some pictures of his Canadian model (working DRL's). The circled relays are the ones related to DRL's. You can see from my earlier pic from my car that the US is missing one of the relays. I had tried putting in a relay there, but it didn't work. So I was hoping that the Canadian version would have a different relay that would explain why my relay placement didn't work. The pics confirm that it is the same relay that is used as all of the others (same as the one I tried). Therefore, a different relay is not the problem and not the easy way of reactivating the DRL's as I had hoped. There is still something else missing that is keeping the DRL's from being activated. As far as I can tell, the only thing missing is a relay there, but that alone is not the problem. All other fuses and relays related are in place.
The suggestion is now to compare wiring diagrams of the Canadian model to that of the US model. No idea how I'll track this down.
To summarize my attempts I've asked the dealership shop (unaware), the regional manager (unaware), Mitsubishi USA hotline ("the US models are not equipped with DRL's" - completely unhelpful, checked fuses (good), checked relays (missing one easily attainable at a nominal cost), now a dead end.
Any other ideas from interested 2016 Outlander owners?
Attached Thumbnails 2016 Outlander SEL DRLs not coming on-img_20160304_182330-edit.jpg
Old Mar 6, 2016 | 09:32 PM
  #48
Smile
Or you could Trade your Outlander in for a Canadian Outlander? Lol you would think they would have that option on the US models
Old Mar 7, 2016 | 08:38 AM
  #49
guxu's Avatar
Did you enable the DRL option in ETACS?
Old Mar 7, 2016 | 11:32 AM
  #50
I asked a question to the forum about this in the ETACS thread, but I didn't get an answer. I haven't done any ETACS mods so I don't know if this will work. It's a bit of an investment to get ETACS so I wanted to know if anyone had experience with the DRL and ETACS. Do you?
