AVG fuel consumption reset
Do you guys have any solution to this? I want to calculate my avg from full tank to empty. But then everytime I change the it to manual it reverts back to automatic and resets by itself after four hours.
Upon fillup, switch into manual-reset and reset. The next time you start your car, it will appear as if it got reset, but it really just switched back to the auto-reset display. If you go back into your menu and to the manual-reset MPG calculator, you will see it has not been reset, only hidden.
You're right! if you check your manual avg you can see the old average until you reset it to zero. As for auto mode it gets reset every after 4 hours or every after you use the vehicle.
Thanks. Now I can check my consumption every refill.
Auto and Manual are two seperate modes.
Auto: Yes resets every so many hours or you can simply press reset at any time.
Manual: Resets only when you press reset - manually.
Yes it does switch back to the Auto mode display every so many hours or so. However the manual mode is still calculating MPG until you switch to manual mode and manually press Reset.
At least this is how it is on my 08 w/Navi. I use the Manual mode to check MPG with every take and then use the Auto mode to check MPG in different driving situations and reset it while on interstate or through town or just different speeds just playing around. So really it is two seperate modes.
Thanks again.
01_Mont.
Nov 29, 2006 12:15 AM
flash3546
Aug 9, 2005 07:16 PM
mturker
Aug 16, 2004 12:41 PM
