Old May 17, 2012 | 04:11 PM
  #1171
Zedicus's Avatar
here it is....maybe. see my test vehicle is nowhere near me so this is untested. if you would like to test it unzip the files, burn them to disc, and stuff it in the mmcd. PLEASE have a backup of your unit, there is a high possibility of this blowing your vehicle up and i take no responsibility. someone with a backup of there HD if your willing to test and report back that would be great.
http://s000.tinyupload.com/index.php...60101633186382
Old May 17, 2012 | 04:40 PM
  #1172
tdford's Avatar
Ive been waiting to do a map update for when this came out. Since I have the first patch for the original '07 nav, I wasnt going to install the update and lose my dvd playback. I wont be able to be your ginnie pig, but if it works Im ordering a map update. 2005 maps SUCK.
Old May 17, 2012 | 10:03 PM
  #1173
Zedicus's Avatar
that file host i found is terible. if anyone gets around to try this, do NOT click the big green download button. on the lower right you want the link for the 6xtst.zip
Old May 18, 2012 | 08:02 AM
  #1174
Zedicus's Avatar
no one?
if not i will try it out this weekend. i just am not around the outlander in the day time.
Old May 19, 2012 | 06:27 AM
  #1175
jbitzer's Avatar
no one?
I'd love to try it, but don't have a backup, sorry.
But if someone does test it and it works, THANKS much for the work!
This is for the newest FW 60. something right? I'm not near the car right now.
Old May 19, 2012 | 08:12 PM
  #1176
Zedicus's Avatar
ive been working on this off and on today. my mmcs is in terrible condition so it takes me 4 times longer to do anything on it then a good one though.
Old May 19, 2012 | 10:23 PM
  #1177
Zedicus's Avatar
its version 60.09. i am currently running my test version that is posted and it is not fully effective. i have noted 1 more key that seems to be different. i am working on locating it in the 60.09 version so that it can be modified.
Old May 20, 2012 | 05:19 PM
  #1178
Papagaiou's Avatar
Great to hear that Zedicus.
Any chance to see a pâtch 60.09 EM? How much different is it from UM?
Old Jun 5, 2012 | 11:59 PM
  #1179
egyeprom's Avatar
hi all
i have 261JM
try to change the lang from Japanese to English with no success
at end i have message in Japanese i think it's about the hdd
here what i do
first i patched it with CD
but didn't remove the battery so nothing happened ..
get the hdd out and unlock it and clone i for emergency ..
get the hdd back with no success still didn't remove battery
after remove battery i got that message ...
i recloned the hdd with file i have from it the but the mmcs give the same message
what i have to do to make it back
the hdd is still unlock . is i have to lock it again ??
so first i need it back to work
and any way to make it english lang ?
thanks alot
Old Jun 6, 2012 | 04:01 AM
  #1180
WiValdiBB's Avatar
Originally Posted by egyeprom
hi all
i have 261JM
here what i do
thanks alot
Hdd is locking with startup procedure of MMCS
I think noone can help You here
UM, RM EM JM MMCS units has installed different firmware, even is some differencies in hardware too.
In my knowledge the only peoples which can do something like that are Russians. From russian forums I know so they can install russion version RM on european EM units
You should look there, ask peoples there and use similar way
To go back with working MMCS You must install good working compatible HDD with right partitions and properly loading.kwi on HDD
After coldboot system should startup
Look into and compare partitions with informations https://mitsubishiforum.com/forum/mi...ructure-37519/
