Lancer wheel on a Outie
Old Nov 27, 2010 | 03:26 PM
piper's Avatar
Default Lancer wheel on a Outie
Hello, I would like to know if the wheel of the Lancer 2008, 2009, 2010 18 inch fit on a Outlander XLS 2008, 18 inch ? I don't know what is the bolt circle of the wheel and the spec. Thank you!
Old Nov 28, 2010 | 08:12 AM
Claude_A's Avatar
Should fit as the specs are the same except for the lip strength rating.
Trucks are JJ and cars are J.
Stock 18" wheels for the Outlander :
Bolt pattern 114.3 mm, (4.5 in.)
Center bore is 67.1 mm,
Rim width is 7 in. (JJ for 4x4's J for normal cars)
Offset 38 mm.
Old Nov 28, 2010 | 11:18 AM
Vadimus's Avatar
Offset 38 mm.
So, Outlanders are considered trucks or cars?
Old Nov 28, 2010 | 11:38 AM
Claude_A's Avatar
With a Gross weight of 5181 lbs it's a heavy car or a light truck.
The 16 inch wheels are JJ but the 18 inch are J.
I guess if you are inclined to go trash the bad land you would use 16 inch high profile tires.
If you are tamer, the 18 inch are paved road wheels hence the J rating.
So the answer is BOTH that's why it's called a CUV.
Old Nov 29, 2010 | 05:00 AM
callross56's Avatar
It fits perfectly in fact my full size spare is off a Lancer.
Old Dec 4, 2010 | 07:42 PM
biscuit's Avatar
The 18" wheels that came on mine are JJ.
Old Dec 5, 2010 | 09:29 AM
Claude_A's Avatar
Must be a market difference as my 18" are J lipped. (Canadian).
Also all of Mitsubishi documentation, on line or in the printed brochure as well as both my user manual (french + English) quote a J lip for the 18" wheel.
An interesting read--> http://www.carbibles.com/tyre_bible_...ml#rimcontours
Also from Toyo Japan--> http://www.toyojapan.com/tire-techno...rim/index.html
This Forum as already discussed this topic
https://mitsubishiforum.com/forum/sh...ad.php?t=34514
Old Dec 5, 2010 | 02:46 PM
Claude_A's Avatar
This is the difference between J and JJ
Old Oct 30, 2011 | 09:02 PM
Vadimus's Avatar
Just bought a set of original Mitsu wheels off old Lancer.
ENKEI OZ Racing F1 16"
ET is 48, will try to install tomorrow.
Old Nov 21, 2011 | 12:43 PM
Vadimus's Avatar
Here are my Lancer wheels installed:
As 3 of 4 OZ center caps were missing, I ordered a replacement stickers. Rims look better with them, and axle nuts are no longer exposed to dust and salt:
sk8dudety
May 31, 2014 08:55 AM
dr_max_facts
Feb 29, 2008 03:21 PM
chillinsb
4th Generation
11
May 31, 2007 03:15 AM
eclipse6racer
Dec 23, 2006 06:16 PM
trbodsm997
Dec 25, 2004 01:52 AM
