OMG! 07 Horn is a joke!
Well its defenetly louder than my Lancer, it does sound high pitched but it makes my wife jump every time I honk when shes opening the garage door for me. So its good enough for me I guess [sm=badbadbad.gif]
For a Japanese horn its not bad but if you want to upgrade grab a set of Magnum Blasters or Stebels. I swapped the puny horns on my FJR for the Blasters - its funny seeing driver/pedestrian reactions when Im on my bike.
get yourself a set of Hella Supertone Horns and you will be happy friends of mine had some on his WRX and man those thing's are lound !
http://www.rallylights.com/hella/supertone_horn.asp
ORIGINAL: antlip
Yea the horn is pretty gay. They should of put an air horn in.
The stocker is a disc type of horn..the advantage is that it's small and the sound is 'aimed' straight out (you can see the horns from the outside so perhaps looks are a factor??)..they sound pretty lame and are usually found on motorcycles and japanese cars
I put an air horn on my bike and it sounds awesome..but they're much bigger (even the compact all in one units), so there could be some mounting issues and I don't trust the opening of the horn to be facing forward getting water/bugs/dirt in there
The signal type (kind of asprial look with a soundexit hole)of electric horn (what has been used in most domestics)..that's proably the sound you want..
ORIGINAL: MadisonMini
Rdenis,
Any idea how easy it would be to swap out our horns and replace them with the Magnum Blasters for the Outie?
Rdenis,
